Articles in this section
Impossible to delete "failed" or "finished with warnings" backups stored on the remote FTP storage
kb: technical Plesk Obsidian for Linux
  • Plesk Obsidian for Linux
  • It is not possible to delete "failed" or "finished with warnings" backups stored on the remote FTP storage
  • Backup checkboxes are not selectable and display the following message when hovering the mouse pointer: "The backup cannot be removed because it is a part of a server, reseller, or customer backup".
  • /var/log/plesk/PMM/migration.log contains the following
    CONFIG_TEXT: INFO: Ftp init url ftps://ftp.domain.tld//backups/backup_example.com_2006030233.tar
    INFO: ImportError Import error: Unable to find archive metadata. The archive is not valid Plesk backup or has been created in an unsupported Plesk version [common/plesk-utils/PMM/repository-transport/PackedDumpHeader.cpp:ImportError]
Corrupted backup file
In order to fix it, the following can be done:
  1. Manually, using some FTP client, move out from folder where Plesk backups located or delete from the remote FTP storage all the files matching pattern *example.com_2006030233*
    Note: Pattern can be extracted from the error message.
  2. Log in to Plesk
  3. Go to Tools & Settings > Backup Manager, and close the message "backup ** was created and can be restored, although some minor issues occurred" and reload the page.
Additional information
Backup structure in Plesk for Linux
