When backing up or copying a large MySQL database in Plesk, the website that uses this database stops responding. CLOSE_WAIT connections can be observed on the server:
# netstat -tanp | grep apache | awk '{print $6}' | sort | uniq -c | sort -n
2 LISTEN
24 ESTABLISHED
62 CLOSE_WAIT -
During a server-wide Plesk backup, all websites are not accessible with one of the following errors:
PLESK_INFO: Error establishing a database connection
PLESK_INFO: 504 gateway timeout
When connecting to the database of an affected website directly via MySQL, the operation fails with the following error message:
CONFIG_TEXT: ERROR 1203 (42000): User database_admin_user already has more than 'max_user_connections' active connections
or the following error when connecting via phpMyAdmin at Domains > example.com > Databases > database_name:
PLESK_ERROR: mysqli::real_connect(): (HY000/1203): User database_admin_user already has more than 'max_user_connections' active connections
By default, mysqldumputility locks all tables and after that performs a data backup which leads to an increase in the number of connections waiting in the queue.
Enable single-transaction option and disable lock-tables in MySQL configuration:
- Connect to the Plesk server via SSH.
- Open MySQL configuration file
my.cnfin a text editor. In this example, we are using the vi editor:-
on CentOS/RHEL-based distributions:
# vi /etc/my.cnf
on Debian/Ubuntu-based distributions:
# vi /etc/mysql/my.cnf
Add these options at the end of the file:
CONFIG_TEXT: [mysqldump]
skip-lock-tables
single-transaction - Save the changes and close the file.
Note: According to official MariaDB documentation, this configuration is a much better option for transactional tables such as InnoDB, because it does not need to lock the tables at all.
Currently, the option single-transaction can be enabled only globally via MySQL configuration file my.cnf.
If you wish to see more flexible options for database backup/copy operations in Plesk, please submit a feature request on our Product Roadmap page:
