Plesk for Linux
kb: technical
curlfails to fetch a website hosted on Plesk when run from inside the server, but works from other locationscurl https://example.com
curl: (7) Failed to connect to example.com port 443: Connection refused -
This domain points to an IP address in
/etc/hosts127.0.0.1 localhost.localdomain localhost
203.0.113.2 example.com -
The IP address assigned to this domain in Domains > example.com > Hosting is different
The entry in /etc/hosts is routing requests to the wrong IP address.
