Plesk is running with an active LiteSpeed Web Server installed with the LiteSpeed extension.
The FastCGI PHP handler is set up at Domains > example.com > PHP Settings.
The PHP information page Domains > example.com > PHP Settings > View the phpinfo() displays the PHP version and/or PHP parameters different from the values at Domains > example.com > PHP Settings.
For LiteSpeed Web Server v5.3 and newer, the PHP Detached Mode was introduced (which is now the default one) - when it's active the new configuration may be applied with a delay.
A new configuration only takes effect once the lsphp
is restarted.
Use one of the following options:
Wait for the
lsphp
process to time out and fork again. -
Restart the PHP Process:
Open Extensions > LiteSpeed.
Click Restart Detached PHP Processes
Note: the PHP handler will restart the next time it is requested by the server, so the configuration might not be updated immediately.
Kill the PHP process:
Connect to the server over SSH.
Manually kill the processes and restart LSHTTPD:
# killall -9 lsphp
# systemctl restart lshttpd
