Emails from a Plesk server can not be sent using a mail client, for example, Outlook:
CONFIG_TEXT: Your IMAP server wants to alert you to the following: Inotify initialization error
Courier IMAP server is used for IMAP/POP3 delivery.
In the
/var/log/mailloglog file the following errors can be found:CONFIG_TEXT: plesk courier-imaps: Failed to create cache file: maildirwatch (jdoe@example.com)
plesk courier-imaps: Error: Too many open files
Insufficient value for per-userid limit of inotify file descriptors.
Check the current per-userid limit of inotify file descriptors:
# cat /proc/sys/fs/inotify/max_user_instances
128 -
Increase this value to a greater one via the command below, for example to 200:
# echo "fs.inotify.max_user_instances=200" >> /etc/sysctl.conf
Note: Rough metric is the number of concurrent IMAP sessions multiplied by 4.
Apply changes by executing the command:
# sysctl -p
Restart Courier-Imap services:
# systemctl restart courier*
