kb: bug
kb: fixed
Plesk for Linux
In the forwarded email message there is excessive "From: SRS" header:
Some mail clients (e.g. Microsoft Outlook or Thunderbird) can display this header in the From field:
Product issue:
#PPPM-13296 "Mail messages forwarded from a Plesk server, or from one mail account to another on the same Plesk server no longer includes an unnecessary duplicate “From:” header."
Fixed in:- Plesk Obsidian 23 November 2021 (Linux)
Workaround
If update is not possible for some reason you may try the following
workaround
Connect to the server via SSH;
Disable add-from mail handler:
# plesk sbin mail_handlers_control --disable --name add-from --type global --queue before-sendmail
