Articles in this section
How to make sure that all FTP clients can establish an FTP or FTPS connection and an FTP data connection to a Plesk server?
Plesk for Windows DoNotDelete:docref kb: how-to Plesk for Linux
  • Plesk for Linux
  • Plesk for Windows
  • How to make sure that all FTP clients can establish an FTP or FTPS connection and an FTP data connection to a Plesk server?
FTP and FTPS connection to a Plesk server depends mainly on the status of the following TCP ports for the public IP addresses of your server:
20 - The FTP data transmission port (for active FTP connections)
21 - The FTP connection port
989 - The FTPS data transmission port
990 - The FTPS connection port
Port range from 49152 to 65535 - The passive FTP connection to the FTP server
You must make sure that all of the ports above are open for all public IP addresses of your server, in all firewalls that reside on your Plesk server and in all firewalls that may reside on levels above the server.
If you want only regular active FTP connections to be possible, it is mandatory that ports 20 and 21 are open in the firewalls.
If you want only regular passive FTP connections to be possible, it is mandatory that the port range from 49152 to 65535 and port 21 are open in the firewalls.
