A notification about a failed system update is received:
There was an issue with updating system packages and third-party components
Error in
/var/log/plesk/systemupdatestool.log:INFO: pum is called with arguments: ['--check']
ERROR: Apt cache fetch failed. Try to run the `apt-get update` command.
ERROR: Err:12 https://download.imunify360.com/ubuntu/20.04/slot-1 focal InRelease
ERROR: Could not connect to download.imunify360.com:443 (157.180.22.9), connection timed out Could not connect to download.imunify360.com:443 (37.27.120.227), connection timed out
ERROR: Err:13 https://download.imunify360.com/ubuntu/20.04/slot-2 focal InRelease
ERROR: Unable to connect to download.imunify360.com:https: - No downtime on the side of Imunify servers
Commands below show no errors:
# plesk sbin pum --check
# apt-get update
Issue with DNS resolution on the server.
Warning: Since /etc/resolv.conf and /etc/systemd/resolved.conf contents are not part of the Plesk configuration and are to be selected by the server or network administrator, it is highly recommended to contact the administrator of your network service before performing any of the operations listed below.
Use these steps to disable systemd-resolved service, and configure reliables open DNS resolver such 8.8.8.8, 8.8.4.4 (Google); 1.1.1.1, 1.0.0.1 (Cloudflare):
- Connect to the server via SSH
Execute the following command to disable
systemd-resolved:# systemctl disable systemd-resolved && systemctl stop systemd-resolved
Use vi to configure the DNS resolvers you would like to use directly in the
/etc/resolv.conffile:# vi /etc/resolv.conf
An example of this file would be:
nameserver 8.8.8.8
nameserver 8.8.4.4
nameserver 1.1.1.1
Does not help.
systemd-resolved was never activated on my server, also changed resolv.conf to Cloudflare/Google last week.
Is it really a dns issue? The given IP addresses in the logs seem to be correct.
Sometimes it is the same for “tuxcare” domain:
Reason: 2026-02-06 06:27:03 INFO: pum is called with arguments: ['--update', '--json']/usr/lib/python3/dist-packages/apt/cache.py:562: Warning: W:Failed to fetchhttps://repo.alt.tuxcare.com/alt-common/deb/ubuntu/24.04/stable/dists/noble/InReleaseCouldnot connect to repo.alt.tuxcare.com:443(157.180.22.9), connection timed out, W:Failed to fetchbtw: when dns lookup fails it looks like this:
Reason: 2026-02-04 07:07:52 INFO: pum is called with arguments: ['--list', '--repo-info', '--json']/usr/lib/python3/dist-packages/apt/cache.py:562: Warning: W:Failed to fetchhttps://repo.alt.tuxcare.com/alt-common/deb/ubuntu/24.04/stable/dists/noble/InReleaseTemporary failure resolving 'repo.alt.tuxcare.com', W:Failed to fetchhttps://download.imunify360.com/ubuntu/24.04/slot-1/dists/noble/InReleaseTemporaryfailure resolving 'download.imunify360.com', W:Failed to fetchIch hab dieses Problem alle paar Tage mit imunify360, eher selten mal mit tuxcare. Alles andere macht keine Probleme.
Grund: 2026-04-03 06:27:24 INFO: pum is called with arguments: ['--list', '--repo-info', '--json']/usr/lib/python3/dist-packages/apt/cache.py:562: Warning: W:Failed to fetch https://download.imunify360.com/ubuntu/24.04/slot-1/dists/noble/InRelease Could not connect to download.imunify360.com:443 (157.180.22.9), connection timed outDas löst das Problem nicht.
