CentOS 7 to AlmaLinux conversion fails in Plesk.
/var/log/leapp/leapp-report.txtsays that the Plesk GPG key is missingRisk Factor: high (inhibitor)
Title: Detected unknown GPG keys for target system repositories
Summary: Some of the target repositories require GPG keys that are not installed in the current RPM DB or are not stored in the /etc/leapp/files/vendors.d/rpm-gpg/,/etc/leapp/repos.d/system_upgrade/common/files/rpm-gpg/8 directory. Leapp is not able to guarantee validity of such gpg keys and manual review is required, so any spurious keys are not imported in the system during the in-place upgrade. The following additional gpg keys are required to be imported during the upgrade:
- http://autoinstall.plesk.com/plesk.gpg
Remediation: [hint] Check the path to the listed GPG keys is correct, the keys are valid and import them into the host RPM DB or store them inside on of the , directories prior the upgrade. If you want to proceed the in-place upgrade without checking any RPM signatures, execute leapp with the--nogpgcheckoption.
Key: e7e3f34a530e861b14f1cdd759cb62f92677066f -
Additional Plesk repositories were added by Plesk extensions
# grep -iR "plesk.gpg" /etc/yum.repos.d/
/etc/yum.repos.d/plesk-ext-watchdog.repo:gpgkey=http://autoinstall.plesk.com/plesk.gpg
/etc/yum.repos.d/plesk-ext-nodejs.repo:gpgkey=http://autoinstall.plesk.com/plesk.gpg
/etc/yum.repos.d/plesk-ext-panel-migrator.repo:gpgkey=http://autoinstall.plesk.com/plesk.gpg
This was caused by a product issue, PPPM-14883, and fixed in Plesk Obsidian 18.0.69, released April 15th, 2025 (Linux).
To resolve the issue, update Plesk to the version with the fix: How to install Plesk updates
If updating is not possible, manually download the key or remove the additional extensions and their repositories.
Download Plesk GPG Key
Log in to the server over SSH
Create this directory if it doesn't exist:
/etc/leapp/files/vendors.d/rpm-gpg/# mkdir /etc/leapp/files/vendors.d/rpm-gpg/
Download the key into this directory
# wget http://autoinstall.plesk.com/plesk.gpg -O /etc/leapp/files/vendors.d/rpm-gpg/plesk.gpg
Run the conversion script
Remove Extensions
List the repositories that use the Plesk GPG key
# grep -r plesk.gpg /etc/yum.repos.d/
/etc/yum.repos.d/plesk-ext-watchdog.repo:gpgkey=http://autoinstall.plesk.com/plesk.gpg -
Remove the listed extensions from Plesk:
# plesk bin extension --uninstall watchdog
# plesk bin extension --uninstall panel-migrator -
