- System logs are not being rotated:
CONFIG_TEXT: -rw-r----- 1 psaadm psaadm 1.5G Jan 25 18:18 /var/lib/plesk/task-manager/runtime/12982/12982/stderr.txt
-rw-r----- 1 psaadm psaadm 1.5G Jan 25 14:18 /var/lib/plesk/task-manager/runtime/12954/12954/stderr.txt
-rw-r----- 1 psaadm psaadm 1.5G Jan 26 07:19 /var/lib/plesk/task-manager/runtime/13111/13111/stderr.txt
-rw-r----- 1 psaadm psaadm 1.5G Jan 26 11:19 /var/lib/plesk/task-manager/runtime/13141/13141/stderr.txt
-rw------- 1 root root 178M Jan 26 13:12 /var/log/plesk-php83-fpm/error.log
-rw-r----- 1 psaadm root 125G Jan 26 13:13 /var/log/plesk/panel.log
-rw-r--r-- 1 root root 485M Jan 26 13:12 /var/log/plesk/httpsd_access_log - Logrotate system package is not installed:
CONFIG_TEXT: # yum list installed |grep logrotate
psa-logrotate.x86_64 3.22.0-2.redhat.9+p18.0.64.0+t240819.0541 @PLESK_18_0_65-dist - Server is using Almalinux/CentOS
Install logrotate system package:
- Execute command:
# yum install logrotate
Last metadata expiration check: 2:39:22 ago on Sun 26 Jan 2025 05:41:20 PM CET.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
logrotate x86_64 3.18.0-8.el9 baseos 74 k
Transaction Summary
Install 1 Package
Total download size: 74 k
Installed size: 153 k
Is this ok [y/N]: y
Downloading Packages:
logrotate-3.18.0-8.el9.x86_64.rpm 2.6 MB/s | 74 kB 00:00
Total 191 kB/s | 74 kB 00:00
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Running scriptlet: logrotate-3.18.0-8.el9.x86_64 1/1
Installing : logrotate-3.18.0-8.el9.x86_64 1/1
Created symlink /etc/systemd/system/timers.target.wants/logrotate.timer → /usr/lib/systemd/system/logrotate.timer.
Verifying : logrotate-3.18.0-8.el9.x86_64 1/1
Installed:
Complete!
Hello,
The issue occurs because the logrotate package is not installed on the server, preventing logs from rotating automatically. To fix it, connect to the server via SSH and install the package by running yum install logrotate. Once installed, automatic log rotation will resume according to Per Your Health the system configuration.
