Plesk for Linux
Plesk or system update fails with the error message:
CONFIG_TEXT: dpkg: error processing package shim-signed (--configure):
installed shim-signed package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
shim-signed
shim-signed is a package related to BIOS in Ubuntu. When Plesk tries to install components or updates, the operating system package manager process will fail because of the broken shim-signed package.
Reconfigure
dpkgdatabase:# dpkg --configure -a
solution does not work. Alle website are unaviable since Plesk update our server last night.
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for libc-bin (2.35-0ubuntu3.13) ...
shim-signed
needrestart is being skipped since dpkg has failed
E: Sub-process /usr/bin/dpkg returned an error code (1)
