Articles in this section
Messages are missing from the system logs: messages lost due to rate-limiting
Plesk for Linux kb: technical
  • Some messages are missing in /var/log/messages, /var/log/maillog or any other log files.
  • The following message can be found in /var/log/messages:
PLESK_INFO: server rsyslogd: imjournal: X messages lost due to rate-limiting
The systemd journal and/or rsyslogd have rate-limiting enabled. When a process generates log messages faster than the configured threshold, messages exceeding the limit are dropped. This results in missing log entries and the "messages lost due to rate-limiting" warning.
To resolve this, one needs to disablve rate-limiting, which can be done through the following steps:
  1. Connect to the server via SSH
  2. Execute the command below:
# pidof systemd && echo "systemd" || echo "other"
 - Follow the steps "for systemd" in case the output is:
PLESK_INFO: 1
systemd
 - Else, follow the steps "for sysvinit"
for systemd
1. Using the vi text editor open the /etc/systemd/journald.conf file.
2. Edit or add the following lines:
CONFIG_TEXT: # Disable rate-limiting of log entries
RateLimitInterval=0
RateLimitBurst=0
3. Open /etc/rsyslog.conf file and remove the rsyslog rate-limiting in the as follows:
CONFIG_TEXT: $imjournalRatelimitInterval 0
$imjournalRatelimitBurst 0
4. Restart rsyslog and systemd-journald services:
# systemctl restart rsyslog
# systemctl restart systemd-journald
for sysvit
1. Edit /etc/rsyslog.conf file and edit or add the following lines:
$SystemLogRateLimitInterval 0
$SystemLogRateLimitBurst 0
2. Restart rsyslog service:
# service rsyslog restart
