Articles in this section
Why after Plesk update to 18.0.53 there's a warning when accessing technical domain for the first time: A technical domain is designed for testing the operation and functionality
DoNotDelete:docref kb: how-to Plesk Obsidian for Linux
No matter how the customer insists, we mustn't disable this banner with any workaround. It was introduced for legal reasons.
After updating Plesk to 18.0.53 on first access to the website resolved to a technical domain, there's a warning. Can it be disabled?
CONFIG_TEXT: A technical domain is designed for testing the operation and functionality of a website. Such domains are never used for original and live websites even if they claim to be so. If you are trying to open the website using a link from the Internet or from an email, we recommend that you proceed with caution.
Starting from 18.0.53 when Plesk technical domain (.plesk.page, .pdns.page, .pleskns.com) is created as a subscription or another Plesk entity that allows hosting, when the customer will visit the page for the first time, the customer will see the following warning banner:
This banner is to prevent phishing cases and can't be disabled.
If this behavior creates an obstacle for the desired workflow, consider using alternative open-source  solutions e.g. https://nip.io/ or https://sslip.io/)
