Articles in this section
Connect to host github.com port 22: Connection timed out fatal: Could not read from remote repository
Plesk for Linux ext: git
  • Plesk for Linux
  • An attempt to enable (clone) remote git repository for a domain via the Git extension for Plesk leads to an error that is similar to the following:
    PLESK_ERROR: Public key for the server at 'github.com' is already known in '/var/www/vhosts/example.com/.ssh/git_known_hosts'. ssh: connect to host github.com port 22: Connection timed out fatal: Could not read from remote repository. Please make sure you have the correct access rights and the repository exists.
  • A direct request for the repository host returns the same time out error:
    # git clone git@github.com:example_user/example.git
    Cloning into 'example'...
    # ssh -T git@github.com
A firewall that resides on a level above your Linux Plesk server blocks outbound connections on port 22 (the default SSH port) and thus prevents the connection to a remote repository server that belongs to github.com.
Contact your server provider in order to receive assistance in opening port 22 (the default SSH port) in any firewalls that reside on levels above your server for your server IP addresses, so that you may gain SSH access to the remote repository host.
