How to add programs to chrooted shell environment template in Plesk?
Note: If it becomes necessary to add too many programs to the chrooted environment, consider offering a hosting upgrade to dedicated or virtual servers.
Log in to the server over SSH
Run this to download and unpack the
update-chroot
script:# curl -o update-chroot.sh https://raw.githubusercontent.com/plesk/kb-scripts/master/update-chroot/update-chroot.sh && chmod 700 update-chroot.sh
Some software won't work in a chroot environment. Refer to its documentation to make sure that it can be added to a chroot environment.
These other articles have links to this script:
https://plesk-new.zendesk.com/hc/en-us/articles/12377475066391
https://plesk-new.zendesk.com/hc/en-us/articles/12377594375703
https://plesk-new.zendesk.com/hc/en-us/articles/12377589132951 -
Add a program to the chrooted environment (examples below)
These examples require SSH access to the server, and the update_chroot.sh
script to be downloaded and unpacked.
Note: Run ./update_chroot.sh --help
for more options (e.g. locale
To add the SSH command into the chrooted environment template, follow these steps.
Add the terminal device inside the chrooted environment template:
# ./update-chroot.sh --devices tty
Note: Without access to
/dev/tty
, SSH will not be able to work. -
Add the SSH executable file itself:
# ./update-chroot.sh --add ssh
Apply changes to one or several specific domains:
# ./update-chroot.sh --apply example-1.com example-2.com
or to all domains at once:
# ./update-chroot.sh --apply all
Now, it is possible to use SSH client while logged in as the domain's user.
Some programs need not just the libraries they link to, but also configuration files and plugins. PHP is one example of such a program.
Note: Adding PHP to the chrooted environment will not benefit the security of PHP scripts on the website, since PHP scripts are executed in a non-chrooted context by the web-server or by FPM process pool.
PHP binary:
# ./update-chroot.sh --add php
Set the variable for the correct Plesk vhost path:
# VHOSTS=`grep HTTPD_VHOSTS_D /etc/psa/psa.conf | awk '{print $2}'`
Add timezone definitions:
# mkdir $VHOSTS/chroot/usr/share
# cp -a /usr/share/zoneinfo $VHOSTS/chroot/usr/share/zoneinfoWarning: Without them, PHP will produce the error whenever date/time functions are used:
glibc detected php: free(): invalid pointer: 0x00007f11249fccd8 ***
Add PHP extensions. They are not added on the first step because PHP binary does not depend on them:
For RHEL/CentOS:
# for i in /usr/lib64/php/modules/*.so ; do ./update-chroot.sh --add $i ; done
For Ubuntu/Debian:
# for i in /usr/lib/php/modules/*.so ; do ./update-chroot.sh --add $i ; done
Note: The path to the modules directory differs between Linux distributions. To find out where PHP modules are stored on the server, run
php -i | grep -E "^extension_dir"
Copy the PHP configuration:
# mkdir -p $VHOSTS/chroot/etc
# cp -a /etc/php.ini /etc/php.d $VHOSTS/chroot/etc/Note: The path to the configuration files differs between Linux distributions. To find out where PHP configuration is stored, run
php -i | grep -E "^Configuration File|^Scan this dir for additional"
Set up default timezone in the main configuration file:
# sed -i.bkp 's/;date.timezone =/date.timezone = Europe\/Zurich/' $VHOSTS/chroot/etc/php.ini
Note: By default the
date.timezone
variable is not set, which can result in some PHP scripts failing to parse the output ofdate("r")
call, because it will return a warning before returning date. -
Note: Changes will not be applied if the Access to the server over SSH value in Plesk > Domains > example.com > Web Hosting Access differs from /bin/bash (chrooted).
Note: Adding PHP to the chrooted environment will not benefit the security of PHP scripts on the website (as PHP scripts are executed in a non-chrooted context by web-server or by FPM process pool).
Set a variable for the PHP version that you want to add:
# PHPPATH='/opt/plesk/php/7.4'
Note: to find the available version use
ls -d /opt/plesk/php/*
Add the PHP binary:
# ./update-chroot.sh --add $PHPPATH/bin/php
Add PHP extensions. They are not added on the first step because PHP binary does not depend on them.
For RHEL/CentOS:
# for i in $PHPPATH/lib64/php/modules/*.so; do ./update-chroot.sh --add $i; done
For Ubuntu/Debian:
# for i in $PHPPATH/lib/php/modules/*.so; do ./update-chroot.sh --add $i; done
# mkdir -p $VHOSTS/chroot$PHPPATH/etc/
# cp -a $PHPPATH/etc/ $VHOSTS/chroot$PHPPATH/; rm -rf $VHOSTS/chroot$PHPPATH/etc/php-fpm.d -
Set up default timezone:
# sed -i.bkp 's/;date.timezone =/date.timezone = Europe\/Zurich/' $VHOSTS/chroot/$PHPPATH/etc/php.ini
date.timezone
Note: Changes will not be applied if the Access to the server over SSH value in Plesk > Domains > example.com > Web Hosting Access differs from "/bin/bash (chrooted)".
Note: Use the full path to executable as user, e.g.:
$ $PHPPATH/bin/php -v
Note: ldconfig
is automatically installed by update_chroot.sh
1.2 and newer when a new application is added to the template.
Add required folders and files to the template:
# cp -a /etc/ld.so.conf* $VHOSTS/chroot/etc
Add ldconfig to the template to rebuild paths:
# ./update-chroot.sh --add ldconfig
Update the linker's configuration:
# chroot $VHOSTS/chroot /bin/sh -c "ldconfig -v"
Apply changes to subscriptions:
