Articles in this section
How to check Plesk server for possible issues before upgrade?
Plesk for Windows DoNotDelete:docref Plesk for Linux kb: technical
  • Plesk for Linux
  • Plesk for Windows
How to check a Plesk server for possible issues before the upgrade?
It can be done using the pre-upgrade checker script.
Follow the instructions below to use it.
Plesk Obsidian 18.0.32 and newer
  1. Connect to the server using SSH or RDP.
  2. Use the pre-upgrade checker:
    • To list available upgrades:
      # plesk listupgrade
    • To run the pre-upgrade checker for checking the upgrade to the latest available version:
      # plesk checkupgrade
    • To run the pre-upgrade checker for checking the upgrade to specific version:
      # plesk checkupgrade 18.0.33
Plesk Obsidian before 18.0.32, Plesk Onyx 17.x, Plesk 12.x
  2. Download the archive with the pre-upgrade checker and unpack it:
  3. Use the pre-upgrade checker:
    Note: On 32-bit operating systems, use the binary preupgrade.386 instead of preupgrade.x64.
    • on Linux:
        # ./preupgrade.x64 list
        # ./preupgrade.x64
        # ./preupgrade.x64 18.0.33
    • on Windows:
      Note: On 32-bit operating systems, use the binary preupgrade_x32.exe instead of preupgrade_x64.exe.
        .\preupgrade_x64.exe list
        .\preupgrade_x64.exe 18.0.33
