Articles in this section
Upgrade Guide to Plesk Obsidian
ABT: Group B kb: auxiliary
  • Plesk
How to upgrade Plesk to Obsidian?
There are two ways to upgrade Plesk Obsidian:
In-place upgrade
An in-place upgrade is performed within one server environment. To perform an in-place upgrade:
  • OS should be supported by its vendor and Plesk
  • Installed Plesk version should support upgrade to Plesk Obsidian. The supported versions are:
    • Plesk Onyx 17.0
    • Plesk Onyx 17.5
    • Plesk Onyx 17.8
    If requirements are met, proceed with the upgrade using the method from this article.
    If an earlier version is installed you can either upgrade to Plesk Onyx first if the installed version supports the upgrade to Plesk Onyx path, or Upgrade by transfer (Below).
Upgrade by transfer
Upgrade by transfer it is the process of upgrading by moving the current environment to the server with Plesk Obsidian installed. To do so:
Proceed with the steps from this article to migrate your server to Plesk Obsidian.
Additional Information
