Articles in this section
Plesk and its command-line utilities do not work due to missing Plesk packages
Plesk for Linux kb: technical
  • Plesk for Linux
  • Plesk is not accessible in a web browser with a "404 Not found nginx" error or a blank page.
  • Plesk command-line utilities are unavailable:
    # plesk -v
    plesk: command not found
    or Plesk version cannot be retrieved:
    # plesk -v
    open /usr/local/psa/version: no such file or directory
  • The plesk-core package is missing on the server:
    • on CentOS/RHEL-based distributions:
      # rpm -qa | grep plesk-core
    • on Debian/Ubuntu-based distributions:
      # apt list --installed | grep plesk-core
Plesk installation is corrupted because the Plesk packages have been removed. System package manager logs may indicate that Plesk packages have been removed recently:
    # grep Erased /var/log/yum.log | grep 'psa\|plesk'
    Nov 01 10:00:00 Erased: psa-firewall-17.8.11-cos7.build1708180301.19.x86_64
    Nov 01 10:00:00 Erased: psa-updates-17.8.11-cos7.build1708180326.12.noarch
    Nov 01 10:00:00 Erased: plesk-core-17.8.11-cos7.build1708180301.19.x86_64
    # grep remove /var/log/dpkg.log | grep 'psa\|plesk'
    2018-01-01 10:00:00 remove psa-mnemo:all 4.2.14-debian8.0.build1708180425.15 <none>
    2018-01-01 10:00:00 remove psa-updates:all 17.8.11-debian8.0.build1708180326.12 <none>
    2018-01-01 10:00:00 remove plesk-core:amd64 17.8.11-debian8.0.build1708180301.19 <none>
This may happen::
- if a Plesk or system package update was interrupted by a system reboot or forced stopping of update-related processes
- during dist-upgrade
- when Plesk packages were partially removed by mistake
  1. Connect to the Plesk server via SSH.
  2. Check if Plesk database exists using the command:
    # MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -uadmin psa
    • if it exists and you are connected to psa database:
      CONFIG_TEXT: MariaDB [psa]>
      then move to step 3.
    • if you get the error message:
      CONFIG_TEXT: ERROR 1049 (42000): Unknown database 'psa'
      restore the Plesk database from the latest daily dump:
      # zcat /var/lib/psa/dumps/mysql.daily.dump.0.gz | sed -n '/-- Current Database: `psa`/,/-- Current Database:*/p' | MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -uadmin
  3. Download Plesk Installer:
    # wget http://autoinstall.plesk.com/plesk-installer
  4. Make the file executable:
    # chmod +x plesk-installer
  5. Start Plesk Installer and install the missing packages:
    # ./plesk-installer
  6. Proceed with the installation.
  7. On Debian/Ubuntu-based distributions, re-link Plesk installation directory using these commands:
    # unlink /usr/local/psa
    # rm -rf /usr/local/psa
    # ln -s /opt/psa /usr/local/psa
