Articles in this section
How to install or update to a specific or legacy Plesk Obsidian version?
Plesk for Windows kb: how-to Plesk for Linux
  • Plesk for Linux
  • Plesk for Windows
  • How to install or update to a specific or legacy Plesk Obsidian version?
  • Is it possible to select the exact Plesk Obsidian version that you would like to update to?
Note: In case Plesk is already installed on a server, only the current Plesk version and Plesk versions to which direct upgrade can be performed will be displayed.
Installing or updating to a specific or legacy Plesk release on a Linux server
  1. Connect to the Plesk server via SSH
    Note: If Plesk is already installed on the server, you can skip steps 2, 3  and 4 and just run the following command instead:
    # plesk installer --all-versions
  2. Download Plesk Installer:
    # wget https://autoinstall.plesk.com/plesk-installer
  3. Add execution permissions to Plesk Installer:
    # chmod +x plesk-installer
  4. Start Plesk installer with the --all-versions key:
    # ./plesk-installer --all-versions
  5. Proceed to the product list and select a desired Plesk release using the numbers.
  6. Start the installation.
    Note: Some legacy Plesk releases cannot be installed on newer operating systems. To see the list of supported and unsupported OSes, visit Plesk Lifecycle Policy.
Installing or updating to a specific or legacy Plesk release on a Windows server
  1. Connect to the Plesk server via RDP
    Note: If Plesk is already installed on the server, you can skip steps 2, 3 and 4 and run the following command instead:
    C:\> plesk installer --console --all-versions
  2. Download Plesk Installer to your Windows server.
  3. Start a command prompt as an Administrator and switch to the directory with downloaded Plesk Installer (By default, C:\Users\Administrator\Downloads):
    C:\> cd C:\Users\Administrator\Downloads
    C:\> plesk-installer.exe --console --all-versions
1 comment
Date Votes
  • by skipping steps 2 and 3, 4 wont work.
    I tried it and 4 says no such file or directoy exists in ssh. you still need plesk.
