Articles in this section
How to prepare the instance with ColdFusion site for upgrade to Onyx
kb: how-to ABT: Group B
  • Plesk 12.5 for Windows
ColdFusion is not supported starting from Plesk 12.5.
Websites which are using ColdFusion engine become unavailable after upgrade to Plesk Onyx with the following error:
CONFIG_TEXT: HTTP Error 401.3 - Unauthorized: Access is denied due to an ACL set on the requested resource.
How to prepare the instance with ColdFusion site for an upgrade to Onyx?
Note: Other CF versions were not tested as they are not supported by Plesk 12.5
  1. Connect to the server via RDP.
  2. Navigate to %plesk_dir%\etc\DiskSecurity folder and create a new file named coldfusion.xml.
  3. Add the content of the downloaded file (depending on the version of ColdFusion installed) to the recently created file:
Additional information
  • In every file [COLDFUSIONX] value should be replaced by actual webroot path of ColdFusion installation, which can be taken from the following registry value:
    CONFIG_TEXT: HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Install Data\Adobe ColdFusion X\WebRoot
  • In every file [COLDFUSION8_CFIDE] value should be replaced by CFIDE value from the following file:
    CONFIG_TEXT: [COLDFUSIONX]servers\cfusion\cfusion-ear\cfusion-war\WEB-INF\cfusion\lib\neo-runtime.xml
