A backup/restoration process completes with the following error message in Plesk:
PLESK_WARN: Cannot stat: Permission denied /bin/tar: Error is not recoverable: exiting now
Migration fails with the following error message:
PLESK_ERROR: Failed to import backup dumps to target panel's repository
Cause: Failed to import backup XML: errcode must be '0' (no errors) or '116' (backup sign error).
Output of pmmcli utility:
<?xml version="1.0" encoding="UTF-8"?>
<response>
<errcode>199</errcode>
<errmsg>Unable to import file as dump: pmm-ras failed (Error code = 1):
STDOUT: migra_info_1909102106.xml
boost::filesystem::status: Input/output error: "/backup_dir/tmp/pmm-dudc-incApacheFiles-KH7Bjv"
STDERR: </errmsg>
</response>
The DUMP_TMP_D location shares the same directory as DUMP_D causing permission conflict.
# grep DUMP /etc/psa/psa.conf
DUMP_D /backup/dumps
DUMP_TMP_D /backup/dumps
Change the
DUMP_TMP_Dlocation to a directory which is different fromDUMP_Dusing the steps from this KB article. For example:# grep DUMP /etc/psa/psa.conf
DUMP_TMP_D /backup/dumptemp -
Set the correct directory permissions and ownership using these commands:
# chown psaadm:psaadm /backup/dumps
# chmod 755 /backup
# chmod 755 /backup/dumps
# chmod 1777 /backup/dumptemp/
