Articles in this section
The System Updates does not work in Plesk: The System Updates tool is already installing updates in automatic mode. Please try later.
kb: technical Plesk Obsidian for Linux
  • Plesk Obsidian for Linux
  • When trying to run System Updates in Plesk > Tools & Settings > System Updates the following error is shown:
The following is shown on attempts to check for updates on command line:
# plesk sbin pum --check
INFO: pum is called with arguments: ['--check']
ERROR: Update operation was locked by another update process (Plesk installer or pum).< ;
ERROR: Exited with returncode 100. exit status 100
There are several Installer processes running:
# ps aux | grep insta
root 13422 0.0 0.0 4444 784 ? S 12:38 0:00 /bin/sh -c "/opt/psa/admin/bin/autoinstaller" "--service-mode" "--enable-xml-output" "--ssl-cert" "/opt/psa/admin/conf/httpsd.pem" "--branch" "release,stable" --web-interface --with-ssl --disable-browser
root 13423 0.0 0.4 79540 19176 ? S 12:38 0:00 /opt/psa/admin/bin/autoinstaller --service-mode --enable-xml-output --ssl-cert /opt/psa/admin/conf/httpsd.pem --branch release,stable --web-interface --with-ssl --disable-browser
root 13424 0.0 0.4 70976 18832 ? S 12:38 0:00 /opt/psa/admin/bin/autoinstaller --service-mode --enable-xml-output --ssl-cert /opt/psa/admin/conf/httpsd.pem --branch release,stable --web-interface --with-ssl --disable-browser
root 14247 0.0 0.0 11744 2268 pts/0 R+ 13:00 0:00 grep insta
Plesk installer processes remain active on a server in the background for 30 minutes. It is expected behavior.
  2. Run the following command:
    # plesk installer stop
Alternatively wait 30 minutes until processes are stopped by Plesk automatically.
1 comment
Date Votes
