- After a Plesk installation or a Plesk upgrade, the following error is shown on the login page:
CONFIG_TEXT: Warning : Unknown: failed to open stream: No such file or directory in Unknown on line 0
Missing symbolic link /usr/local/psa/ -> /opt/psa/
Connect to the server using SSH
Remove the link
/usr/local/psaif there is any:# unlink /usr/local/psa
In case of error
unlink: cannot unlink '/usr/local/psa': Is a directoryrename the directory directory/usr/local/psa:# mv /usr/local/psa{,.bak}
Create a symbolic link
/usr/local/psa/ -> /opt/psa/:# ln -s /opt/psa /usr/local/psa
Reinstall Plesk updates as described in the article How to update Plesk
This however, won't work if Plesk version is already the latest. In this case, navigate to http://autoinstall.plesk.com or http://origin.autoinstall.plesk.com/pool/ , download the respective version of the plesk-core package and install it using dpkg/rpm. For example:
# wget http://autoinstall.plesk.com/PSA_18.0.37/dist-deb-Debian-10.0-x86_64/base/plesk-core_18.0-v.debian.10+p18.0.37.1+t210802.1246_amd64.deb && dpkg -i plesk-core_18.0-v.debian.10+p18.0.37.1+t210802.1246_amd64.deb
