Articles in this section
Custom iptables rules are reset after a system reboot on a Plesk for CentOS 7 or CloudLinux 7 server
Plesk for Linux kb: technical ABT: Group A
  • Plesk for Linux
  • Custom iptables rules are reset after a system reboot on a Plesk for CentOS 7 or CloudLinux 7 server
  • firewalld system service is removed or disabled
The iptables-services package is not installed. This means the custom iptables rules are not applied after a server restart.
Warning: The package iptables-services might cause incompatibility issues with Imunify360. Make sure to stop Imunify360 before applying these steps and start the service after.
Apply the following steps:
Click on a section to expand
1- Add the custom iptables rules
2- Save iptables rules persistently
  2. Install the iptables-services package:
    # yum install iptables-services
  3. Disable firewalld, enable iptables system service and start it:
    # systemctl stop firewalld
    # systemctl disable firewalld
    # systemctl mask firewalld
    # systemctl enable iptables
    # systemctl start iptables
  4. Save the iptables rules:
    # service iptables save
