Articles in this section
A website hosted in Plesk is not accessible: 401 Authorization Required
Plesk for Windows Plesk for Linux kb: technical
  • Plesk for Linux
  • Plesk for Windows
  • A website is asking for a username and a password. When clicking Cancel, one of the following errors appear in a web-browser:
    PLESK_INFO: Authentication required
    PLESK_INFO: 401 Authorization Required
  • When opening the phpinfo() page at Domains > example.com > PHP Settings > View the phpinfo() page, the following error message is shown in Plesk:
    PLESK_ERROR: Error: Unable to retrieve information about the PHP configuration.
The website's Document Root ("/") is protected either at Domains > example.com > Password-Protected Directories or in the .htaccess file (Linux).
As a result, website visitors unable to see the website content without authorization.
Apply one of the following solutions:
Solution I: Disable the password protection for the Document Root ("/") of the website
  1. Log in to Plesk.
  2. Go to Domains > example.com > Password-Protected Directories.
  3. Select the document root directory and click Remove Protection:
    On a Linux server, if the password protection directory for "/" does not exist, open the .htaccess file via Plesk File Manager and remove the following lines:
    CONFIG_TEXT: AuthType Basic
    AuthName "Secure Content"
    AuthUserFile /var/www/vhosts/example.com/httpdocs/.htpasswd
    require valid-user
Solution II: Add a user in Plesk and allow him to access the website with the password
Add a user in Plesk and allow him to access the website with a password using the steps from this KB article.
