kb: how-to
Plesk
ABT: Group A
- Plesk
How to set passive FTP port range from Plesk interface?
Plesk for Windows
Go to Home > Tools & Settings > FTP Settings and set passive FTP port range:
Plesk for Linux
This feature is not available at the moment. If you’d like to suggest it for future Plesk updates, you can submit a feature request here: https://features.plesk.com/
Suggestions with the most votes are more likely to be considered for upcoming Plesk versions.
As a workaround use the following guide:
Enabling Passive FTP (Linux)
Additional information
Configuring Passive FTP Mode on a Google Cloud Instance
Configuring the Passive FTP Mode on an Amazon EC2 Instance
Configuring the Passive FTP Mode on a Microsoft Azure Instance
