Articles in this section
Upgrade to Plesk Obsidian or update between Obsidian releases fails: TypeError: an integer is required
kb: bug kb: fixed Plesk Obsidian for Linux ABT: Group B
  • Plesk Obsidian for Linux
The following error appear at the log after failed Plesk update or during upgrade to Plesk Obsidian:
CONFIG_TEXT: Error: Cannot open file /var/cache/yum/x86_64/6/PLESK_17_PHP70/packages/plesk-php70-sodium-2.0.13-0centos.6.181207.1259.x86_64.rpm: [Errno 2] No such file or directory: '/var/cache/yum/x86_64/6/PLESK_17_PHP70/packages/plesk-php70-sodium-2.0.13-0centos.6.181207.1259.x86_64.rpm'
error: python callback <bound method RPMTransaction.callback of <yum.rpmtrans.RPMTransaction instance at 0x6324e18>> failed, aborting!
processTransaction event: 10 (Downloading Packages)
processTransaction event: 11 (unknown)
Product issue:
  • #PPPM-11218 "On servers running an RPM-based Linux with Yum, it is no longer possible to run the yum clean all command during the update, which led to the update failing."
    Fixed in:
Workaround
If update is not possible for some reason you may try the following
workaround
  2. Check for duplicate packages with the command below:
    # package-cleanup --dupes
    Note: package-cleanup utility is provided by yum-utils package. If the package is not installed use yum install yum-utilsto install it.
  3. Make sure that important packages will not be removed and then remove duplicates using the following method:
    Warning: It's highly advised to have a full server backup before proceed with further steps of this article.
    # package-cleanup --cleandupes
  4. Re-check duplicates:
    • If any package still reported, remove it manually
      # rpm -e --nodeps --noscripts <package_name>
  5. Complete the upgrade:
    # plesk installer update
