Plesk for Windows
kb: technical
- Plesk for Windows
Plesk is not accessible with error message
CONFIG_TEXT:HTTP 500 error
Unable to run Plesk CLI utilities, for example:
C:\> plesk login
exit status 255 - Creating a domain/subdomain gets stuck in UI without any progress.
Plesk Update process has been interrupted by server reboot.
Connect to the server via RDP
- Start the command prompt as the Administrator
Resume the Plesk update with the following command:
C:\> plesk installer
