When enabling Fail2Ban jails, the operation fails with:
PLESK_ERROR: Unable to switch on the selected jails: f2bmng failed: fail2ban [7690]: ERROR NOK: ("Failed to initialize any backend for Jail 'plesk-roundcube'",)
ERROR:main:Command '['/usr/bin/fail2ban-client', 'reload', '--if-exists', 'plesk-roundcube']' returned non-zero exit status 255
ERROR:main:Failed to reload following jails due to errors in configuration: plesk-roundcube. -
The following error message is logged in
/var/log/fail2ban.log:CONFIG_TEXT: Backend 'systemd' failed to initialize due to No module named systemd
systemd is set as default backend in jail.local file:
CONFIG_TEXT: grep -r 'backend' /etc/fail2ban/jail.local
backend = systemd
Note: file could be different, e.g. /etc/fail2ban/jail.d/local.conf
Open the file
/etc/fail2ban/jail.localin a text editor. In this example, we are using the vi editor:# vi /etc/fail2ban/jail.local
Remove or comment the following line, or change it to
backend = auto:CONFIG_TEXT: backend = systemd
Save the changes and close the file.
Restart the Fail2Ban service:
# systemctl restart fail2ban.service
