kb: how-to
Plesk for Linux
ABT: Group B
How to check and restore permissions for files inside domain's document root on Plesk for Linux?
- Connect to the server via SSH.
- Execute the following command to check and show files with non-default permissions (644 for files, 755 for directories)
# plesk repair fs -n -verbose example.com
- To set the default permissions, execute the following command:
# plesk repair fs -y example.com
I have done above commands, but web page doesn't load:
11:47 root@mail:/var/www/vhosts/radiopik.pl/httpdocs# plesk repair fs -n -verbose radiopik.pl
Checking virtual hosts' file system ................................. [OK]
Error messages: 0; Warnings: 0; Errors resolved: 0
11:48 root@mail:/var/www/vhosts/radiopik.pl/httpdocs# plesk repair fs -n radiopik.pl
Log:
2025-11-24 11:57:34 Error 178.73.4.114 403 GET /action.php?action=toponair&n=1&program=1 HTTP/1.0 7.52 K Dostęp apache SSL/TLS
2025-11-24 11:57:34 Error 178.73.4.114 [core:crit] (13)Permission denied: AH00529: /var/www/vhosts/radiopik.pl/httpdocs/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable and that '/var/www/vhosts/radiopik.pl/httpdocs/' is executable, referer: https://www.radiopik.pl/ Błąd Apache
How to repair this?
