kb: how-to
Plesk for Linux
How to skip repository check during Plesk installation?
The repository_check.sh script is responsible for the repository check during the Plesk installation. It is possible to create a flag-file that will make this script skip the entire checking process.
Perform the following:
Connect to the server via SSH
Execute the command below to create the flag-file:
# touch /var/cache/plesk-installer-skip-repository-check.flag
Note: For Plesk versions below 18.0.82, use the following path instead:
# touch /tmp/plesk-installer-skip-repository-check.flag
To have this file permanent, surviving server reboots, add the command from step 2 as a cron task.
