Articles in this section
WordPress instance inside a sub-directory on Plesk server shows "404 Page not found" errors for existing categories or posts
kb: bug kb: fixed Plesk for Linux ext: wptk
  • Plesk for Linux
  • Existing Posts or Categories from a WordPress instance installed under sub-directories (e.g. /httpdocs/test) return "404 Page Not Found", "Not Found" or "Nothing Here" error.
  • Permalinks at WordPress admin Dashboard > Settings > Permalinks page are set differently than "Plain" (e.g. Post Name) at the WordPress instance installed under the sub-directory. ​
Product issue:
  • #EXTWPTOOLK-8578 "Block author scans and Enable bot protection security measures no longer break WordPress sites installed in a subdirectory."
    Fixed in:
Workaround
Apply one of the following workarounds:
Use "Plain" permalinks:
  1. Login to the WordPress admin Dashboard of the sub-directory instance.
  2. Go to Serttings > Permalinks page.
  3. Select Plain option and click Save Changes.
Revert Security Measures "Block author scans" and "Enable bot protection":
Revert the Security Measures "Block author scans" and "Enable bot protection" on the main WordPress instance (/httpdocs) and under Wordpress instances installed to subdirectories (e.g. /httpdocs/test), as described below:
  1. Log into Plesk.
  2. Go to Domains > example.com > WordPress > select the WordPress instance in question > Security Status or Security page and press Check Security button.​
  3. Select Block author scans and Enable bot protection, if both are found applied, otherwise select the one found and press Revert button:
