Articles in this section
Running a Cron job via Scheduled Tasks in Plesk fails: Permission denied
Plesk for Linux kb: technical ABT: Group B
  • Plesk for Linux
  • When executing a scheduled task that runs a command to execute a script in Plesk, it returns a Permission denied error:
    PLESK_ERROR: Task " php -q /var/www/vhosts/example.com/httpdocs/wp-cron.php" completed with error in 0 seconds, output:
    -: /dev/null: Permission denied
    -: php: command not found
Lack of permissions on the script file or missing command in the chroot environment.
  1. Log in to Plesk.
  2. Change the shell for the subscription to /bin/bash in Subscriptions > example.com > Web Hosting Settings > Access to the server over SSH.
    Note: The next step is not necessary in case the executable file cannot be accessed via Plesk File manager.
  3. Correct permissions or task type.
    • For shell scripts:
      Find the affected file in Domains > example.com > File Manager and add executable permissions:
    • For the .php scripts:
      Recreate the task as Run a PHP script one in Domains > example.com > Scheduled Tasks > Add Task:
