How to enable Queues in the Laravel project for Plesk Laravel Toolkit
4 comments
    Mario Küpfer (Edited )
    This change throws an error on all existing projects that do not have the corresponding package installed:
    There are no commands defined in the "plesk-ext-laravel" namespace.
    [2023-01-26T13:21:00.443049+00:00] production.ERROR: There are no commands defined in the "plesk-ext-laravel" namespace. {"exception":"[object] (Symfony\Component\Console\Exception\NamespaceNotFoundException(code: 0): There are no commands defined in the "plesk-ext-laravel" namespace. at /var/www/vhosts/***redacted***/application/vendor/symfony/console/Application.php:632)"} []
    1
    Ensure you not run "php artisan optimize" during deployment. Otherwise the toggle is deactivated.
    Martin Allen
    Seeing the same issue - looks like it might be occurring when artisan schedule:run is being called each minute??
    [2023-01-27 15:09:44] development.ERROR: There are no commands defined in the "plesk-ext-laravel" namespace. {"exception":"[object]
    (Symfony\\Component\\Console\\Exception\\NamespaceNotFoundException(code:
    0): There are no commands defined in the \"plesk-ext-laravel\"
    namespace. at
    /var/www/vhosts/xxxxx/vendor/symfony/console/Application.php:624)
    [stacktrace]
    #0
    /var/www/vhosts/xxxxx/vendor/symfony/console/Application.php(675):
    Symfony\\Component\\Console\\Application->findNamespace()
    #1
    /var/www/vhosts/xxxxx/vendor/symfony/console/Application.php(259):
    Symfony\\Component\\Console\\Application->find()
    #2
    /var/www/vhosts/xxxxx/vendor/symfony/console/Application.php(171):
    Symfony\\Component\\Console\\Application->doRun()
    #3
    /var/www/vhosts/xxxxx/vendor/laravel/framework/src/Illuminate/Console/Application.php(111):
    Symfony\\Component\\Console\\Application->run()
    #4
    /var/www/vhosts/xxxxx/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(155):
    Illuminate\\Console\\Application->run()
    #5 /var/www/vhosts/xxxxxx/artisan(37):
    Illuminate\\Foundation\\Console\\Kernel->handle()
    #6 {main}
    Ken Cline
    Yep. It's broken.
