Plesk for Windows
kb: fixed
kb: bug
- Plesk for Windows
Manually enabled ASP.NET component is not displayed at Tools & Settings > Server Components page and can not be selected for domain at Domains > example.com > Hosting Settings page.
The same issue can be seen for other components installed/enabled not via Plesk UI.
Product issue:
#PPPM-13797 "Clicking Refresh on the Tools & Settings > Server Components screen now results in the list of installed components being updated as intended."
Fixed in:- Plesk Obsidian 18.0.49 20 December 2022 (Windows)
Workaround
If update is not possible for some reason you may try the following
