Plesk can not be updated or is not accessible: Class Laminas\ServiceManager\ServiceLocatorInterface cannot implement previously implemented interface
13 comments
    dev it
    i can't login to the plesk dashbord , when i try to login an error message : ERROR: Class Laminas\ServiceManager\ServiceLocatorInterface cannot implement previously implemented interface Psr\Container\ContainerInterface (ServiceLocatorInterface.php:18)
    so how can i do this with ssh ?
    Ismael Dobarrio
    Update the Monitoring extension to the latest version with the command below:
    plesk bin extension --upgrade monitoring
    1
    dev it
    @ismael thank you , is there a possibility to connect to the server without loging on my plesk ?
    i didnt install ssh on plesk
    Ismael Dobarrio
    The other possibility is to connect directly through root to the server. (also by ssh)
    dev it
    when i tried with ssh  :
    connection closed by port 22
    Anastasia Zyrianova
    Hello dev it,
    Please contact your hosting provider to obtain SSH access. As soon as this is done, execute the command from the article to update the Monitoring extension.
    1
    dev it
    1
    daniel rodriguez
    # plesk bin extension --upgrade monitoring
    this was used recently by me in windows 2016 server + plesk (RDP login) and it worked properly under CMD, thanx for your support  :)
    1
    Anastasia Zyrianova
    Hello dev it,
    All the Plesk related-commands should be executed under user root or with root privileges. Try using the command below:
    # sudo plesk bin extension --upgrade monitoring
    1
    dev it
    thank you , the problem is resolved
    i connect to ssh as debian user, then i change to a root
    then i executed the command and it worked thanks
    1
    Luis Fernando Acevedo
    I have problems, I have followed the steps , the result is
    "the extension was successfully upgraded"
    But still the access to the plesk server is still failing:
    "ERROR: Class Laminas\ServiceManager\ServiceLocatorInterface cannot implement previously implemented interface Psr\Container\ContainerInterface (ServiceLocatorInterface.php:18)"
    Félix Iglesias (Edited )
    Solved as well!
    Goncalo Silva
    Logged by ssh , solved!
    Thank you
