The local laws of my country require storing all server logs for a long period. How do I set up storing of websites' logs for years in Plesk?
Important
- Plesk recommends you not to disable log rotation and not to store log files for a long period, because it may cause overuse of the disk space and affect the server performance.
- Please note that when you remove a website, you remove its logs as well. To prevent that from happening, store required log files on a remote/external storage or a database. You can use third-party log management software or a bash script provided below.
To set up a non-standard period of log storage, do the following:
To keep sensitive data safe, disable the IP addresses anonymization in Plesk. Go to Tools & Settings > Server Settings, clear the Anonymize IP addresses during log rotation and collecting of web statistics checkbox and click OK:
Download and configure the actual version of archive-logs.sh script.
Note: the corresponding repository may be found here.
Configure a scheduled task to run a script in a periodic manner.
Here's how the typical script setup steps look like:
CONFIG_TEXT: # # make sure the script is executable
# chmod +x archive-logs.sh
# # check help
# ./archive-logs.sh --help
# # create a config from sample
# ./archive-logs.sh -s > config.sh
# # edit it to suite your environment and target storage
# # execute the script with the config to check everything works as expected
# ./archive-logs.sh -c config.sh -l debug
# # add the command to root cron with desired period: "/path/to/archive-logs.sh -c /path/to/config.sh"
# # note that "-c /path/to/config.sh" can be skipped if the file is in the same directory as the "archive-logs.sh" script
Below you can get the detailed instruction on how to use the archive-logs.sh script.
Script
By default, this script collects all known logs of the server, Plesk, and websites. You can view the list of the collected logs right in the script and modify it in a configuration file if required.
To get a list of available options, run the script with the --help option:
Usage: archive-logs [OPTIONS]
Collect and transfer logs for long-term storage.
-c, --config CONFIG
Use this config (default: 'config.sh' in the directory
of the script). Config defines where to upload logs,
how to do it, which additional logs to include, and
some other settings. Use '--show-config-sample' to
obtain a sample. Do not make the config world-writable.
-l, --log-level LEVEL
Set logging level, one of: 'ERROR', 'WARNING', 'INFO',
'DEBUG' (default: 'WARNING'). Logs are written to
stdout, additional error output from children and
the script errors may appear on stderr.
-n, --dry-run
Simulate operation, don't create or transfer files
-s, --show-config-sample
Print config.sh sample and exit
-h, --help
Display this help and exit
With default config this will simply copy all logs to '/tmp/cold-storage-example'.
To customize the script, create a configuration file using the sample:
First, the script will collect all logs that match LOG_GLOBS (except for the logs that match LOG_IGNORE_PATTERNS) to STAGING_DIR. Then it will call TRANSPORT_CMD STAGING_DIRTRANSPORT_DEST to transfer the collected logs from the staging directory to the configured storage.
When collecting logs that are to be copied, COPY_STRATEGY will be used (which should be accounted for by TRANSPORT_CMD).
When collecting logs that are to be compressed, COMPRESS_CMD and COMPRESS_EXT will be used. COMPRESSED_EXTENSIONS will also be used to recognize already compressed logs.
You can adjust the script's behavior by overriding the transport(), compress(), and log_filter() functions.
Rotated logs are compressed and suffixed with the UTC timestamp of their modification time (mtime) to ensure their names are reasonably unique. Non-rotated logs are typically left uncompressed.
The script does not change any actual logs on the server itself, but only copies them or creates new compressed versions in the staging directory.
To run the script with the minimal configuration, specify TRANSPORT_DEST ( the storage where logs will be stored).
You can also choose the desired utility that will be used to copy the logs; f.e. cp, rsync, scp, etc.
CONFIG_TEXT: ## Command to use as transport from staging to storage.
## Typical examples: cp, rsync, scp.
## The command should accept two arguments: staging directory and destination (see below).
## The command should account for COPY_STRATEGY (see below).
#TRANSPORT_CMD=(cp -arT)
## Transport destination (the storage). Should be understandable by the TRANSPORT_CMD above.
#TRANSPORT_DEST="/tmp/cold-storage-example"
Run the script:
CONFIG_TEXT: # copy to mounted storage (all logs on one partition)
TRANSPORT_DEST="/mnt/storage"
COPY_STRATEGY="hardlink"
CONFIG_TEXT: # copy to mounted storage (/var/www/vhosts is on a separate partition)
TRANSPORT_CMD=(cp -arTL)
COPY_STRATEGY="link"
CONFIG_TEXT: # sync to remote storage
TRANSPORT_CMD=(rsync -avi)
TRANSPORT_DEST="root@storage.example.net:/path/to/storage"
CONFIG_TEXT: # sync to remote storage and don't create /path/to/storage/archive-logs sub-directory at destination
transport()
for src in "$@"; do
"${TRANSPORT_CMD[@]}" "$src/" "$TRANSPORT_DEST"
done
- Make sure your TRANSPORT_CMD does not remove files missing in STORAGE_DIR at TRANSPORT_DEST, but only adds or updates existing ones.
- Using rsync or a similar tool as transport provides optimal updates to the storage and minimizes the traffic and transfer time.
- If your transport tool fails on copying logs that are being written to, use COPY_STRATEGY="copy" instead.
