Plesk for Windows
Plesk for Linux
kb: technical
ext: wptk
- Plesk for Windows
- When scanning instances in Plesk > WordPress > Scan the existing instance for
example.com
does not appear in the list. - The instance for
example.com
has been detached from WordPress Toolkit recently. - The WordPress Toolkit extension version is 5.9.2 and above.
Starting from WordPress Toolkit 5.9.2 detached WordPress instances are no longer re-added through the Scan
procedure, making their detachment permanent.
If the website should be added to WordPress Toolkit back for some reason, perform the following:
- Log into Plesk.
- Go to Domains > example.com > File Manager.
- Find and remove the
.wp-toolkit-ignore
file in the domain's document root. - As soon as the file is removed, go to the WordPress menu and re-scan instances.
2 comments
i have deleted it and found that in a few times it was successful, but now my hundreds of hosting are not showing anything after scanning, the .wp-toolkit-ignore file also doesn't exist
no .wp-toolkit-ignore file for me still unable to detect the site. I used the manual connection with plugin.
