Plesk for Linux
kb: fixed
kb: bug
- WordPress Toolkit Feature Autodetection of WordPress login URL does not work properly when using PerfMatters plugin or Block wp-login Plugin
- Although Custom WordPress login URL was changed via Plugin, WordPress Toolkit recognizes default wp-login.php as login URL
Product issue:
#EXTWPTOOLK-8565 "WordPress Toolkit can now properly detect login URL that was changed by Perfmatters plugin. Make sure you have updated the plugin to version 1.8.7 or higher. Special thanks to Perfmatters team for helping with this issue quickly."
Fixed in:- WordPress Toolkit 5.10.0 17 March 2022
Workaround
If update is not possible for some reason you may try the following
workaround
Until the bug is fixed, use one of the supported plugins below to change the WordPress login URL:
- WPS Hide Login
- Change wp-admin login
- Hide My WP Ghost Lite
2 comments
Great!
I'm using https://de.wordpress.org/plugins/wp-hide-security-enhancer/ to change the login URL. As I cannot manually edit the URL, there is no way to login from plesk. Will you be adding compatibility for that plugin? Or at least the option to manually override the auto detected url?
