Platform 360
Plesk 360
360 monitoring dashboard in Plesk shows:
CONFIG_TEXT: 401 Not authorized
- It may also show error:
CONFIG_TEXT: 404 Not found
Safari is used with default browser settings, "Prevent cross-site tracking" is enabled in particular.
Some modern browsers by default block necessary cookies.
The behavior is under investigation in order to find the solution.
It is a bug CPCLOUD-1334.
Currently, one of the following workaround might be used:
- Use other browsers than Safari
- Disable the option "Prevent cross-site tracking" under Safari > Preferences > Privacy
- Check data directly on https://monitoring.platform360.io/dashboard/overview page
