Unable to repair domains in Plesk using "plesk repair db" utility: The following domains are assigned to already removed IP addresses
3 comments
    Ops-team
    select val from dom_param where dom_param.param='ip_addr_id' and val not in (select id from IP_Addresses) group by val;
    Der Select gibt aus welche IDs gesetzt sind die es als IP gar nicht (mehr) gibt. Keine Ausgabe = alles gut!
    Michael Koontz
    The command in Step 4 above is missing the trailing quote.
    This article helped me fix my problem.
    Alex Davydov
    Michael Koontz thank you for this notice. The article was corrected.
