- Plesk Obsidian for Linux
Recycle bin is enabled and the
plesk repair fs
utility does not correct permissions for the trash directory:# plesk repair fs -vhosts -verbose
Checking virtual hosts' file system
There are incorrect permissions on some items in the root directory
of the domain 'example.com' ....................................... [ERROR]
- Incorrect group of /var/www/vhosts/example.com/.trash: expected
is psaadm (1000), actual is psaserv (1002)
Do you want to repair incorrect permissions? [Y/n] y
Repairing incorrect permissions ................................. [FIXED]
There is incorrect ownership on some items in the WWW root directory
is psaserv (1002), actual is psaadm (1000)
Do you want to repair incorrect ownership? [Y/n] y
Repairing incorrect ownership ................................... [FIXED]
Error messages: 2; Warnings: 0; Errors resolved: 2
This is the Plesk bug with ID #PPP-52464 that has been fixed on Plesk Obsidian 18.0.38.
