Mail client provides warnings regarding IMAP connection for Plesk mailboxes: inotify initialization error
2 comments
    Quentin Di Meo
    Hi Anastasia Zyrianova,
    Thank you for this post.
    We did increase the inotify value up to 300 but the warning is still showing up on Outlook clients.
    A customer email address is only used on one computer so very few connections.
    What do you recommend in this case?
    Thank you in advance and wish you have a good day.
    Anastasia Zyrianova (Edited )
    Hello Quentin Di Meo,
    Check the current per-userid limit of inotify file descriptors using the command below, and adjust the `fs.inotify.max_user_instances` value accordingly:
    # cat /proc/sys/fs/inotify/max_user_instances
    In case the issue still persists after that, check /var/log/maillog log file for details.
