After updating Plesk on Linux server to version Obsidian 18.0.37, the following notification is sent daily to the Plesk administrator by Watchdog:
CONFIG_TEXT: ERR [panel] No entry is registered for key 'translate':
0: /usr/local/psa/admin/plib/vendor/plesk/zf1/library/Zend/Registry.php:147
Zend_Registry::get(string 'translate')
1: /usr/local/psa/admin/plib/CommonPanel/Validate/Mailname.php:44
Plesk\CommonPanel\Validate\Mailname->_setupMessageTemplates()
2: /usr/local/psa/admin/plib/CommonPanel/Validate/Regex.php:20
CommonPanel_Validate_Regex->__construct(string '/^[\w-'][\w&+-'](.[\w&+-']+)$/')
3: /usr/local/psa/admin/plib/CommonPanel/Validate/Mailname.php:33
Plesk\CommonPanel\Validate\Mailname->__construct()
4: /usr/local/psa/admin/plib/AbstractChecker.php:233
AbstractChecker::email(string 'support@jdoe.com')
5: /usr/local/psa/admin/plib/functions.php:1312
plesk_mail(array, string 'Watchdog daily report Jul 25, 2021 (Sunday) on localhost.localdomain', string 'Watchdog is running since Jul 26, 2021 05:45 PM.
Watchdog is monitoring services:
Plesk Web Ser...', boolean false, string 'watchdog@localhost.localdomain')
6: /usr/local/psa/libexec/modules/watchdog/cp/send-report:108
Product issue:
- #PPPM-13128 "In Plesk 18.0.37 and later, Watchdog daily reports sent to the Plesk administrator by email no longer contain the “ERR [panel] No entry is registered for key ‘translate’” errors."
Fixed in:- Plesk Obsidian 10 August 2021 (Linux)
3 comments
My server (Contos 8) did an automatic update to version 18.0.37 Update #2, after update the server gave an error I did a reset and it worked, but now the email service (postfix) does not work. The emails are in Queue and do not send.
How can I solve this problem? Please it is urgent.
Ich habe nach dem Update Plesk Obsidian 18.0.37.2 die folgende Fehlermeldung
Type: Zend_Exception
Message: No entry is registered for key 'translate'
File: Registry.php
Line: 147
Ein plesk repair funktioniert leider auch nicht, weil auch dort die Message: No entry is registered for key 'translate'
Gibt es noch andere Tools die helfen können
Does anyone has the same issues after upgrading to 18.0.37.2???
I do not find any information what is needed in Registry.php on line 147
Do anyone know whats ment
