kb: technical
ABT: Group B
- Plesk
There are two ways to upgrade to Plesk Onyx:
In-place upgrade
In-place upgrade is performed within one server environment. To perform in-place upgrade:
OS should be supported by its vendor and Plesk;
Installed Plesk version should support upgrade to Plesk Onyx.
The supported versions are:- Plesk 12.5
- Plesk 12.0
- Plesk 11.5 (upgrade to Plesk Onyx 17.0 or 17.5 only)
- Plesk 11.0 (upgrade to Plesk Onyx 17.0 or 17.5 only)
If requirements are met, proceed with the upgrade using method from this article.
If an earlier version is installed you can proceed with Upgrade by transfer.
Upgrade by transfer
Upgrade by transfer it is the process of upgrade by moving current environment to the server with Plesk Obsidian installed. To do so:
- OS should be supported by its vendor and Plesk;
- Currently installed Plesk version should support migration to Plesk Onyx. Currently Plesk for Linux and Windows 8.6 and later are supported.
Proceed with the steps from this article to migrate your server to Plesk Onyx.
Additional Information
