- Plesk Onyx for Linux
- Plesk Onyx for Windows
High CPU load on a server with a great number of domains (a few hundreds) and ServerShield by Cloudflare extension.
There are a log of the processes like below during Plesk Daily Maintenance task:
CONFIG_TEXT: /usr/local/psa/admin/bin/event_handler -i -u psaadm /usr/local/psa/admin/bin/php -- -f /usr/local/psa/admin/plib/scripts/interface_async_executor.php -- EventListener /usr/local/psa/admin/plib/modules/servershield/library/EventListener
/var/log/plesk/panel.log
with enabled debug mode shows the following entries:CONFIG_TEXT: DEBUG [panel] [5d518d4c54248] Asynchronously call interface implementation /usr/local/psa/admin/plib/modules/servershield/library/EventListener.php
This is a ServerShield by Cloudflare extension bug which should be fixed by Cloudflare. For tracking purposes internal ID #EXTPLESK-1202 has been created for this issue.
For Linux as a temporary workaround apply the following hotfix:
Connect to the server via SSH
Backup the file
:# mv /usr/local/psa/admin/plib/modules/servershield/library/EventListener.php{,.orig}
Download the archive with the patched file, unpack it and replace the backed up file with the patched file:
# wget https://plesk.zendesk.com/hc/article_attachments/360044365053/EventListener.tar.gz
# tar -zxvf ./EventListener.tar.gz
# mv ./EventListener.php /usr/local/psa/admin/plib/modules/servershield/library/
For Windows servers replace the original file %plesk_dir%\admin\plib\modules\servershield\library\EventListener.php
with the patched one from the same archive in attachments to this article.
