Installation fails with:
CONFIG_TEXT: UnicodeEncodeError: 'ascii' codec can't encode character u'\xdc' in position 0: ordinal not in range(128)
Execute command /usr/local/psa/admin/bin/send-error-report install --version 17.8.11
Warning: Failed to attach to cgroup /sys/fs/cgroup/systemd/user/root/tasks, installer might be unexpectedly killed later by the system
Error: Failed to run the Yum utility.
The Yum utility failed to install the required packages.
Attention! Your software might be inoperable.
Please contact product technical support. -
Server is running on CentOs with German locale:
# locale
LANG=de_DE.UTF-8
LC_CTYPE="de_DE.UTF-8"
LC_NUMERIC="de_DE.UTF-8"
LC_TIME="de_DE.UTF-8"
LC_COLLATE="de_DE.UTF-8"
LC_MONETARY="de_DE.UTF-8"
LC_MESSAGES="de_DE.UTF-8"
LC_PAPER="de_DE.UTF-8"
LC_NAME="de_DE.UTF-8"
LC_ADDRESS="de_DE.UTF-8"
LC_TELEPHONE="de_DE.UTF-8"
LC_MEASUREMENT="de_DE.UTF-8"
LC_IDENTIFICATION="de_DE.UTF-8"
LC_ALL= -
LANGUAGE variable is not empty:
# echo $LANGUAGE
de_DE.UTF-8
Incorrect value for $LANGUAGE
which causes yum-python to decode UTF symbols with ASCII code.
It is considered as a bug in the product with ID #PPPM-10782 which is planned to be fixed in future Plesk updates.
Note: Consider subscribing to this article in order to receive updates on this bug or check by the bug ID in our Changelog
As a workaround:
Connect to the server via SSH
Run the installer with an empty
LANGUAGE
variable:# env LANGUAGE= ./plesk-installer
