Unable to create git repository in Domains > example.com > Git > Add repository;
Cannot open Git menu under Domains > example.com > Git:
PLESK_ERROR: Server Error
500
Type PleskUtilException
Message filemng failed: filemng: Error occurred during /usr/bin/base64 command.
File Agent.php
Line 228 -
Unable to create a subdomain under Domains > Add Subdomain:
PLESK_ERROR: PleskUtilException: filemng failed: filemng: Error occurred during /usr/bin/base64 command. (Agent.php:228)
The error below appears in the /var/log/plesk/panel.log
CONFIG_TEXT: ERR [util_exec] proc_close() failed ['/opt/psa/admin/bin/filemng' 'edfh' 'base64' '/var/www/vhosts/example.com/.ssh/id_rsa.pub'] with exit code [1]
ERR [1] '/opt/psa/admin/bin/filemng' 'edfh' 'base64' '/var/www/vhosts/example.com/.ssh/id_rsa.pub' failed with code 1.
stdout:
base64: /var/www/vhosts/example.com/.ssh/id_rsa.pub: Permission denied
Incorrect permissions for the .ssh
directory and/or files inside it. Files should be owned by subscription user and group psacln
Determine the system user for subscription using the path to the vhost (see error from
for reference):# grep example.com /etc/passwd
johndoe:x:10000:1003::/var/www/vhosts/example.com/:/bin/false -
Set the system user as owner for all files of the
.ssh
directory inside virtual host:# chown -R johndoe:psacln /var/www/vhosts/example.com/.ssh/
