- Plesk Onyx for Linux
Migration from cPanel (as well as Pre-migration checks) when started via Plesk Graphical interface works slowly in case when there are many domains hosted on the source server;
NOTE: The number of domains to migrate might be low
On the source cPanel server output of the below command shows that migration dump creation is in process:
# ps axf | grep plesk_migrator
/root/plesk_migrator/plesk_migrator-9s4zttf661ivs5hg2938tvgf7g2pq0f9/pmm_agent; /usr/bin/perl createDump.pl --dump-all --configuration-only --server -v 5 > dump.log 2>&1
Plesk Migrator bug with ID #PMT-4626, which is planned to be fixed in product future updates.
As workaround proceed with migration via CLI instead.
