"Keep websites secured" is not enabled by default in Plesk SSL It! extension
5 comments
    Plawansai
    Who could Click Update & Sync? I rent the hosting, but I didn't find this page.
    Ivan Postnikov
    Hello Plawansai
    An administrator of a Plesk installation has such permission.
    Fouad Ahmed Fouad
    How to modify this option through CLI for all domains at the same time, please advise?
    Anton Maslov
    Hello Fouad Ahmed Fouad please try this command:
    plesk bin subscription --list | while read subs; do plesk bin subscription --add-custom-plan-item $subs -custom-plan-item-name "urn:ext:sslit:plan-item-sdk:keep-secured"; done
    1
    Fouad Ahmed Fouad
    Hi Anton,
          Thanks for helping, I did it on a server and seems it worked fine.
    I think Plesk should have some of these options enabled by default so you make admin's life much easier!
    Suppose SSL is not working fine and many clients are calling you complain their mail programs stopped working!
    I recommend Plesk enable this by default to avoid down times for mails and web sites which depend on SSL!
